Hello Guest it is November 13, 2026, 07:59:43 PM
Author Topic: Slave Axis  (Read 25335 times)
Re: Slave Axis
« Reply #10 on: December 23, 2010, 12:17:33 PM »
Just make sure it's as square as possible when you mount the nuts, as they'll bind if out of alignment.
Offline kolias
  •  1,165 1,165
Re: Slave Axis
« Reply #11 on: December 23, 2010, 12:51:56 PM »
Thanks Gerry, and Happy Holidays
Nicolas
Offline kolias
  •  1,165 1,165
Re: Slave Axis
« Reply #12 on: February 05, 2011, 05:19:30 PM »
When you "reference" the machine, Mach3 travels to the home switch, and sets the axis to machine coordinate zero when it hits the switch.
With slaved motors, each motor can move to it's own switch independently. So if the gantry is out of square, each side will move until it hits it's switch, squaring the gantry back up.
A home switch can be used as a limit switch, and vise versa.
Tomorrow I will install two limit switches on the Y / A axes which will be used as Home switch. On the Y axis I will also install another limit switch which will define the travel at the opposite end of Home.
One thing I dont understand; lets assume that the gantry is out of square by 1/4". When the gantry hits the first limit switch lets say on Y axis would Mach3 stop the motor on the Y axis and keep running the motor on the A axis until the gantry is square?
And how Mach3 knows that the gantry is square?
Nicolas
Offline kolias
  •  1,165 1,165
Re: Slave Axis
« Reply #13 on: February 05, 2011, 05:23:09 PM »
Sorry, dont know what I did wrong with my previous post
Nicolas
Re: Slave Axis
« Reply #14 on: February 05, 2011, 05:38:03 PM »
Each needs it's own switch. The Y and A will move together, the Y stops when it hits the Y switch, the A stops when it hits the A switch.
It's up to you to position the switches so it ends up square. :)
Offline kolias
  •  1,165 1,165
Re: Slave Axis
« Reply #15 on: February 05, 2011, 06:18:26 PM »
Thanks Gerry, I got it
Yes I have separate home switch for the Y and A
Nicolas
