Hello Guest it is October 14, 2026, 09:36:43 PM
Author Topic: Tribal Router II Ports and Pins Help!  (Read 14809 times)
« on: November 29, 2010, 10:36:32 AM »
So had some computer issues last week, long story short I have a new computer. Talked with Keith at Vortech and he told me all I needed was the Ports and Pins configuration and I would be good to go again. Received the email this morning, it's an XML file and I believe I am supposed to copy-paste it to a Tribal Router II file, the only thing is, I have no clue how to get there and they're not very big on answering the phone at Vortech, so now I'm here. Any help would be greatly appreciated.
Nolan
Re: Tribal Router II Ports and Pins Help!
« Reply #1 on: November 29, 2010, 11:13:18 AM »
Nolan,
Keep in mind, I know nothing about Vortech, but an XML file "should" go into the Mach 3 folder if that's what you are using?
« Reply #2 on: November 29, 2010, 11:44:10 AM »
Correct, Mach 3. That's the thing though I'm not sure what file I am supposed to paste it into.
« Reply #3 on: November 29, 2010, 11:47:33 AM »
Ok, great, then just drop the xml file into the Mach 3 folder and you should be able to find that profile when you click on the Mach 3 "loader" icon on your desktop. That will start up your Mach s software with the correct XML configuration that you received from Vortech.
Hope that helps-
« Reply #4 on: November 29, 2010, 12:12:10 PM »
Where do I find this Mach 3 folder? All I have is: Mach 3 Loader, Mach 3 Plasma, Mach 3 Mill, Mach 3 Mill and Mill on my desktop.
Nolan
« Reply #5 on: November 29, 2010, 12:16:36 PM »
This Mach 3 folder is in the directory on the hard drive on your computer, wherever you (or Vortech) installed Mach 3. The default place is the C: Hard drive.
« Reply #6 on: November 29, 2010, 12:30:10 PM »
Ok, so just place the XML file in there and that'll work?
Nolan
« Reply #7 on: November 29, 2010, 01:51:31 PM »
Again, I know nothing about Vortech but the XML should have all the info that is required to run your machine.
Test at YOUR own risk or contact Vortech for confirmation!!
« Reply #8 on: November 29, 2010, 03:12:49 PM »
Alright, I finally got it! Thanks for all of your help.
Nolan
« Reply #9 on: November 29, 2010, 03:16:45 PM »
Excellent, thanks for letting us know.
