Hello Guest it is November 24, 2026, 08:35:19 PM
Author Topic: Scale X-1 Problem  (Read 51550 times)
Re: Scale X-1 Problem
« Reply #30 on: December 02, 2010, 10:25:55 AM »
Excellent news, thanks Brian.
Mike
« Reply #31 on: December 04, 2010, 02:45:35 PM »
I'm sorry to have to visit this again but I have spent the last two days converting all my files back to using the R word only for arcs as Brian had said he had fixed it. On cursory inspection all seemed to be okay but as I was getting ready to machine, I zoomed in on the toolpath screen and to my horror, the -1 scaling problem has returned. I have attached a couple of screen shots that show the problem clearly. You should be able to read the code line that is creating the arc highlighted in the toolpath screen.
Incidentally, this is Gerry's (Ger) new screen set and, in my opinion, one of the best yet devised for Mach. Not released yet but looking good. Nice one Gerry.
Mike
« Reply #32 on: December 04, 2010, 03:26:28 PM »
Aaaaargh, same happens when the Y axis is used too!!
Mike
« Reply #33 on: December 06, 2010, 08:38:46 AM »
I think I need to send you an EXE to play with to see if it is working better for you .. if you would Mail me off list and I will send you the new EXE
www.newfangledsolutions.com
www.machsupport.com
« Reply #34 on: December 07, 2010, 09:01:47 AM »
Mike
Is that a Flash screen?  I have to agree.  It's one the nicest Mach screens I've seen.  I like the tabbed panel.  It really cleans things up.
« Reply #35 on: December 07, 2010, 01:42:37 PM »
Hi rrc1962,
I did not design the screen set, that was the work of Gerry (ger21) and I am sure he will chip in and correct me if I am wrong but I don't think it is a Flash screen. I'm pretty sure it was done using MachScreen designer.
Mike
« Reply #36 on: December 07, 2010, 05:19:01 PM »
No Flash, it's a regular .set screen done with Screen4.
http://www.machsupport.com/forum/index.php/topic,16609.0.html
