Hello Guest it is November 11, 2026, 11:14:38 PM
Author Topic: Plasma table issues  (Read 26464 times)
Offline Fritz
  •  18 18
Re: Plasma table issues
« Reply #10 on: November 29, 2010, 07:16:50 AM »
Hey Hood! Actually made a cut on Friday. I cut out an octagon.Still having the issue of when i reference the "y" axis. It is still moving to the opposite end of the table to reference. Still have to fix it. Also, on Friday, I had to turn down the feedrate percentages down on the program run screen for mach3. This is after the optimum travel has been set along with the arc voltage. Thanks, Fritz
« Reply #11 on: November 29, 2010, 07:22:57 AM »
You can reverse the homing direction by changing the home negative setting for the Y, you will get it from Config menu then Homing and Limits.
Offline Fritz
  •  18 18
« Reply #12 on: November 29, 2010, 07:56:54 AM »
Cut an octagon on Friday! Cut was nice! However, i had to turn the feedrate down on the mach3 program run screen. This is after i set the optimum travel speed and set the correct arc voltage. Also, gantry still wants to travel to the opposite end of the table after the "y" axis is referenced. The 2 stepper motors start grinding and the carriage doesn't want to move! On the octagon, all the vertical (y axis) cuts have a rigid finish. Seem to have a racking problem. It is supposed to correct itself after referencing but doesn't! Thanks, Fritz
Offline Fritz
  •  18 18
« Reply #13 on: November 29, 2010, 08:56:50 AM »
Hey Hood! my issue now is the "y" axis motors (stepper) they are making a grinding noise when i move the gantry w/ the hotkeys or when i reference. Any ideas?
Offline Fritz
  •  18 18
« Reply #14 on: November 29, 2010, 08:58:11 AM »
I did adjust the homing like you said and still moves in the wrong direction.
Offline Fritz
  •  18 18
« Reply #15 on: November 29, 2010, 01:16:42 PM »
Hey Hood! Still with the issue of the wrong direction when i reference. I went ahead and adjusted the settingsl like you suggested. Still not working.
« Reply #16 on: November 29, 2010, 04:33:20 PM »
Ok can you attach your xml and also tell me the position of your home switches.
