Hello Guest it is November 20, 2026, 10:49:35 AM
Author Topic: VisualMill bridges ?  (Read 8211 times)
Offline kak
  •  81 81
« on: November 13, 2010, 02:03:55 PM »
Hello
Im running simulations in VisualMill, adding tabs/bridges (2,5D profiling) to keep my part inside the material, but all 3D toolpaths are milling the bridges away.  Is it normal? When I choose outline of my part as a machining region and run 3d finish path with a ballmill, there is a little bit of the briges left ( not enough), because my tool stops when it reach the machining region, but if I choose the region a little bit outside the part, the bridges are gone.
How can I keep the part inside my material or just the same place?  I don`t have any holes in the part, its just a 3d surface.
« Last Edit: November 13, 2010, 02:06:55 PM by kak »
