Hello
Guest
it is
November 20, 2026, 10:41:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
How can I speed up three axis movement
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How can I speed up three axis movement (Read 9396 times)
LarryL
61
on:
November 09, 2010, 10:27:29 AM »
I am installing a third axis on my CNC Quilter. It will have the X-axis, y-Axis, and A-axis. When the code executes, i.e. x1.0000 y1.0000 A2.0000, the x and y motion has to wait for the A motion to complete before moving on to the next line. This causes the movement of the x and y axis to stop moving. Is there a way to overcome this? The whole idea behind the CNC Quilter is that the motion will be smooth and the A-axis will move at the same time the Y axis moves without interfering with it's operation. Any ideas?
Larry
Logged
BR549
6,965
Re: How can I speed up three axis movement
Reply #1 on:
November 09, 2010, 05:09:19 PM »
What is the orintation of the axis's on the machine? To coordinate the feedrates you may have to assign a diamter to the a axis so Mach knows how to do the feedrate to match that of XY
AS is mach is moving the a axis in deg per min while the xy is inch per min.
Look on the settings page top right under A axis set the radius to match what the A actually is when running.
Then look in CONFIG under the TOOLPATH tab then check the box for USE radius for feedrate
NOW mach will move as fast as the Axis will rotate. IF your a axis is slow then mach will be slow as well.
Last Edit: November 09, 2010, 05:11:12 PM by BR549
Logged
LarryL
61
Reply #2 on:
November 10, 2010, 01:42:58 AM »
Hey BR549,
Thanks for the info, I'll give that a try and see what happens. I'll let you know later today (Wednesday) how it goes. I am in Germany, so there is a bit of lag in response.
Larry
Logged
Print
Pages:
1
Go Up
« previous
next »
