Hello Guest it is November 28, 2026, 09:35:20 AM
Author Topic: z height self reset  (Read 17303 times)
fiordlander
z height self reset
« on: November 02, 2006, 04:41:40 PM »
Hi, My system frequently resets the z cutting height midway through executing a file. It doesn't happen all the time. Can anyone shed light on this ?
Re: z height self reset
« Reply #1 on: November 02, 2006, 08:11:00 PM »
Do you have an external  button that will set the Zheight?
www.newfangledsolutions.com
www.machsupport.com
fiordlander
« Reply #2 on: November 02, 2006, 09:59:16 PM »
just the ones within mach3.
« Reply #3 on: November 03, 2006, 09:31:42 AM »
Have had similar experience - but it always appears to be the result of something I have screwed up.  Generally this has occurred when when producing G-code in LCAM and I failed to notice a "Z" height or depth change.  Now, I make it a practice to edit the G-code and look for changes in the "Z", parameters.
Bob @ BobsShop
fiordlander
« Reply #4 on: November 03, 2006, 02:34:54 PM »
OK good suggestion.At least it will stop it happening.Thanks
fiordlander
« Reply #5 on: November 04, 2006, 10:16:12 PM »
Found the problem which was interference from cad program minimised in tray bar.
« Reply #6 on: November 05, 2006, 08:22:47 AM »
Is this a closed case? Will you confirm that it is fine now and the error was caused by
Just trying to keep up.
fiordlander
« Reply #7 on: November 05, 2006, 03:57:20 PM »
Yes Problem solved. It was definitely some call the minimised cad programme was making.
