Hello Guest it is October 15, 2026, 10:31:44 PM
Author Topic: Output problem.  (Read 23630 times)
Re: Output problem.
« Reply #10 on: November 03, 2010, 02:34:46 AM »
Fixed it.  I had the motor contols direction pin also set to pin 1, which was the output pin for output#2.   Thanks guys for your assistance.   ;D
Re: Output problem.
« Reply #11 on: November 03, 2010, 02:52:36 AM »
Which pins on the G540 are  the relay pins?
Re: Output problem.
« Reply #12 on: November 03, 2010, 02:55:34 AM »
Re: Output problem.
« Reply #13 on: November 03, 2010, 03:00:37 AM »
Yes I have just looked myself.
Ok so you have Pin 17 connected to OutPut 1 and have that enabled as the spindle relay so that should work fine. You however have Pin 1 as both the Spindle Dir pin and also OutPut3. If you are wanting to use Pin 17 as an enable signal then I dont think you should have it as either  of these but rather have it as an enable.
