Hello Guest it is October 21, 2026, 06:32:14 AM
Author Topic: Huge Threading Problem Help  (Read 77614 times)
Re: Huge Threading Problem Help
« Reply #40 on: October 26, 2010, 11:35:50 PM »
What is interesting here is Cartierusm stated no spindle speed with Vn .40, just 7rpm, that is exactly what I got. When Vn.32 was tried looks like it was sucessful.
I`ve tried vn.20 and spindle speed is ok, vn.40 no spindle speed,no matter what the debounce or M3. I now need to try V.32, but I`m 6000miles from my workshop at the moment so that will have to wait! Anyone got spindle speed with Vn.40 and parallel port? Can you share your relevant "Turn" settings please!
Thanks, Woody.
Offline TomS
  •  17 17
« Reply #41 on: March 20, 2011, 09:04:41 AM »
Hello,
a little bit older, but actual: I have updated from 042.020 to Vn.043.022. Everything o.k. but no Spindle Speed?
I have two LPTs, Pokeys, all o.k.- but no Spindle Speed at the Display. "Downdate" to 042.032 was not sucessful, same failure.
What the failure?
Greetings from Germany,
Tom
« Reply #42 on: March 20, 2011, 09:08:10 AM »
Are you telling Mach your  spindle has started by issuing a m3 or m4?
Offline TomS
  •  17 17
« Reply #43 on: March 20, 2011, 09:27:09 AM »
Yes, but nothing...
Greetings, Tom
« Reply #44 on: March 20, 2011, 09:45:51 AM »
Can you attach your xml andI will see if I can find a problem.
Offline TomS
  •  17 17
« Reply #45 on: March 20, 2011, 02:15:41 PM »
Here comes...
Tom
« Reply #46 on: March 20, 2011, 02:22:16 PM »
Go to config menu then Ports and Pins then Spindle Setup and take the tich out of the Disable Spindle relays box. Doesnt matter if you dont have anything assigned for the outputs.
Offline TomS
  •  17 17
« Reply #47 on: March 20, 2011, 03:10:19 PM »
Yeah,
hier comes the speed. Many thanks!
But: If I turn off the speed, even when turned off is still a low speed (continous) in the display ... Is there also a change?
Greetings, Tom
« Reply #48 on: March 20, 2011, 04:50:12 PM »
Did you tell Mach the spindle was stopped by calling a M5 or pressing the spindle button?
Offline TomS
  •  17 17
« Reply #49 on: March 21, 2011, 02:13:15 AM »
No,
The control of the Spindle via VFC is manual. That was until now correctly ...
Greetings, Tom
