Hello Guest it is October 27, 2026, 06:34:59 AM
Author Topic: I have an IPM problem  (Read 25734 times)
Re: I have an IPM problem
« Reply #10 on: October 21, 2010, 04:22:28 PM »
does anyone else have any Ideas how to fix this problem??
Joe,curious about something.
- When you run the driver test at 25000 what frequency does it display for your computer?
  Does it change and if so how much?( roughly)
- With Mach open what pulse frequency is displayed in the diagnostics?
« Reply #11 on: October 23, 2010, 07:59:40 AM »
ok so I ran the printer test and the pulse per second are running at 23500 instead of 25000.. So does that mean that there is a printer port problem or a CPU problem?
« Reply #12 on: October 23, 2010, 10:36:49 AM »
I'm not sure I'd call it a problem. It's just that your PC runs Mach3 a bit slower than normal, resulting in a slower than expected feedrate. What type of processor are you running?
« Reply #13 on: October 23, 2010, 12:05:42 PM »
P4 1.6ghz
