Hello Guest it is October 27, 2026, 03:57:02 AM
Author Topic: Mach3 + Galil + Gecko  (Read 7475 times)
« on: October 18, 2010, 02:08:42 PM »
I have a Galil card 18x2, ICM 2900, and three Gecko g201's driven by Mach3.
The x axis, y axis, homing limits on x and y axis, and estop are working beautifully.
Now, I am working on the z axis and I am totally stumped. I cannot seem to get the motor to move physically, on the screen, or using plain old g code.
1. I enabled the z axis in ports and pins, step pin to 6, direction to 7
2. I played with settings of dir low active and step low active and it made no difference - no movement
3. I am using a motor and driver that worked great on the x axis which eliminates the motor and driver as potential culprits
4. confirmed that the stepper jumper was on the galil card dmc-1832
and still no physical movement on the x axis or numerical movement on the screen
What am I missing?  My guess is that it is something simple but  I have run out of things to test.
Re: Mach3 + Galil + Gecko
« Reply #1 on: October 19, 2010, 09:40:12 PM »
Figured it out.
Within Mach3:
Goto Config - plugin control - double click the config button next to the @galil barker .... part
click on axis setup
Select z(c)
bingo the axis is active
