Hello
Guest
it is
November 21, 2026, 03:19:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
dspMC/IP Motion Controller
(Moderator:
Vital System Support
Fixture Offsets
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Fixture Offsets (Read 103807 times)
egerber
29
Re: Fixture Offsets
Reply #20 on:
October 06, 2010, 07:10:25 PM »
Sure it can't hurt
I will post results in the morning
Logged
Carnoustie, Scotland
Re: Fixture Offsets
Reply #21 on:
October 06, 2010, 07:12:28 PM »
Ok, hopefully the issue can be found by all this testing, certainly have never seen anything like that here.
Logged
egerber
29
Re: Fixture Offsets
Reply #22 on:
October 07, 2010, 12:13:08 PM »
Thank every one for your input
Here is the scenario
Did nothing to Y axis configuration
changed config to Ignore Tool Change
Added M1 to stop program between tool changes (every thing runs perfect)
Changed M1 to M0 to eliminate the possibility of optional stop being turned off and crashing the tool (same results)
Pryor to those changes
I fount that if a axis moved in the wrong direction you can open the Save fixture page select X save Y save then restart the tool and every will run correctly
Will advise if any thin changes
Logged
Re: Fixture Offsets
Reply #23 on:
October 07, 2010, 01:42:39 PM »
Thats good news in as much as you can now run OK.
Can you attach the M6 macros, maybe there is something in them that is affecting things.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
