Hello Guest it is October 22, 2026, 03:41:38 PM
Author Topic: all the stuff needed on the screen??  (Read 16956 times)
Offline Arbo
  •  50 50
« on: September 27, 2010, 08:05:19 PM »
I am using the Aqua screenset... which I modified to clear it up and get rid of some unused things.
But I was considering doing a new one based on it, and clearing up more stuff.
Just curious if a general screen set designed for the hobbyist who has a home brew CNC machine with a router thus no spindle speed or misting and or tool infol that would be of interest to anyone but me.   Not sure what all else is important to others.   I know for all the buttons/functions,   I use load gcode, edit gcode, run, pause, stop, rewind, run from, auto z zero, adjust and reset feed speed... but not much else.
Any input would be great.
thanks
« Last Edit: September 27, 2010, 08:09:20 PM by Arbo »
Offline Arbo
  •  50 50
Re: all the stuff needed on the screen??
« Reply #1 on: September 27, 2010, 08:08:13 PM »
oh, and occasionally use a wizard, but most of them seem like a jumbled confusing mess to me...
« Reply #2 on: September 27, 2010, 08:47:28 PM »
Since I made the Aqua set, I'll give you my take.
Make it exactly how you want. Once you start to cater to others, it'll just keep growing.
I actually only use about 10% of what I put in Aqua.
I'm currently (on and off) working on a very simplified Flash screen. I started making it for other users, but scraped that and will make it exactly how I want it. If others like it fine. If not, oh well. :)
And btw, a lot of people make very simple screens for their own use, so there probably would be a demand for it.
Offline Arbo
  •  50 50
« Reply #3 on: September 27, 2010, 08:57:05 PM »
I thought about making it as I want, at least for the main screens...  Aqua has been the best I have seen so far.   Though perhaps I should just learn all the other
things mach can do as perhaps I am missing useful stuff.
Offline GeorgeRace
  •  53 53
  • My Home Built Airplane
    • Race Consulting
« Reply #4 on: September 28, 2010, 06:16:28 AM »
Hi Arbo:
I went through the same user curve as you are going through.  I built a SimpleMill set for my own use and made it available for others.
It may well be a starting point for you to look at.  I did both a three and four axis set.  It only has two screens and I built it to do just what I was doing, nothing more.
Incidentally, it was based on ger21 Aqua Screen Set.  I used that for some time as well.
You can see and download it at:  http://www.mrrace.com/SimpleMill/
George
Check out my home page
Offline Arbo
  •  50 50
« Reply #5 on: September 28, 2010, 10:24:32 AM »
Thanks, that is definately more basic.
Offline Arbo
  •  50 50
« Reply #6 on: September 29, 2010, 05:19:54 PM »
Well, I started moving around buttons and re-organizing a bit...  this is what I have so far... using the buttons from Aqua...   much more to go, including the tedious work of editing the grey away from the edges of the buttons..
Offline GeorgeRace
  •  53 53
    • Race Consulting
« Reply #7 on: September 29, 2010, 06:59:08 PM »
Hi Arbo:
If it would help you can download my button set they are very similar and do not have any of the gray outlines.  I built all new ones when I built the screen set.
George
« Reply #8 on: September 29, 2010, 07:05:35 PM »
In my Aqua thread, there's a link to the Photoshop files for my buttons. Should be a lot easier to edit.
