Hello Guest it is November 05, 2026, 04:54:05 AM
Author Topic: Mach 3 turn constant sfm?  (Read 86439 times)
Re: Mach 3 turn constant sfm?
« Reply #40 on: January 15, 2011, 03:43:07 PM »
Just made up a quick spreadsheet to convert surface speed to RPM for a given dia and feed per tooth to feed per min.
Thought it might be of use to others if they are like me, ie paper gets lost in my workshop within 10 seconds ;D
« Last Edit: January 15, 2011, 03:46:04 PM by Hood »
« Reply #41 on: November 26, 2013, 12:38:12 PM »
Regards G96, I want to control the speed through the programme. I have an inverter powering a 2HP motor. can I use either the spare Y axis or A axis pin on the printer port to give the PWM. Is there another way of doing it
Regards Jason
