Hello Guest it is November 08, 2026, 03:45:20 AM
Author Topic: Anyone running an Ajax controller with Mach3?  (Read 8026 times)
« on: September 23, 2010, 07:51:12 PM »
I converted a Milltronics Pardner 4 to Ajax and I need some friends to talk with about it. It uses Mach3 with an Ajax plugin. The ajax documentation is real skechy, so I've been looking to the Mach3 forum for help. Now I'm finding the Ajax plugin doesn't work the same as the standard Mach3. I'm stuggling a little bit to sort it out. I'm hoping someone has run an Ajax controller and could give some tip on setup, like limits and homing. I almost have it up and running.
Thank you
