Hello Guest it is October 03, 2026, 12:29:56 AM
Author Topic: Auto Zero Touch pad and c10 (cnc4pc board)  (Read 10808 times)
« on: September 23, 2010, 11:18:19 AM »
I think i would like to build me a touch pad to use for Zeroing my Z axis.
I have a c10 board from cnc4pc.  Which pin will i attach the leads to?
What is the command in Mach3 to have the mill come down and zero the Z?
Or do i move it down with MPG until it hits the pad?
Im just not sure of the process after i wire up the pad to use it.
Thanks for the help bob
Sorry the question is not worded better
Re: Auto Zero Touch pad and c10 (cnc4pc board)
« Reply #1 on: September 23, 2010, 02:07:44 PM »
You need to use a macro to do the tool  setting, there are a few about and you should find them if you search for auto tool zero
As for pin on the breakout, any spare input should be fine.
« Reply #2 on: August 14, 2011, 12:19:11 PM »
Has anyone out there wired a touch pad into a Syil X4 control cabinet.  I am not an electrician, and when I open the cabinet door, I am overwhelmed.
« Reply #3 on: August 14, 2011, 12:22:17 PM »
And when I wired in my coolant pump, I found that the inside components were not laid out as the cabinet schematic, Syil China had to send me marked up pictures of where they moved things and which component was what...
