Hello Guest it is October 20, 2026, 03:02:04 PM
Author Topic: Exactly how are home switches supposed to work?  (Read 23517 times)
Offline Greolt
  •  956 956
Re: Exactly how are home switches supposed to work?
« Reply #10 on: September 18, 2010, 07:06:11 AM »
  Let's say you have a microswitch as your home switch and it's operated by a cam, the home point
on the left side of the cam, may be in a different place to the home point on the right side of the cam.
For this mid axis home switch system to work, the home switch must be held active from the activation point all the way to one end of travel.
It can NOT, for example, be activated by a cam momentarily as the axis moves and then comes off the cam as movement continues in the same direction.
For this reason, to my mind, non contact switches are the best option.  Proximity or optical.
Mechanical roller type switch would wear out the roller in normal use.
Greg
« Reply #11 on: September 18, 2010, 09:18:11 AM »
"Let's say you have a microswitch as your home switch and it's operated by a cam, the home point
on the left side of the cam, may be in a different place to the home point on the right side of the cam."
The part I think you missed is if approaching from the correct side, lets say right side. It moves left untill it trips the switch then back s off to the right untill it untrips.
NOW if you are to the left of the switch. It moves right untill it trips then KEEPS going right until it untrips the switch. So the untrip points should be the same point as it occurs in the same direction AND the same point on the cam ,going right.
Just a thought, (;-) TP
