Hello Guest it is November 03, 2026, 06:25:16 AM
Author Topic: CamBam Gcode problems  (Read 24408 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: CamBam Gcode problems
« Reply #10 on: September 16, 2010, 07:39:05 AM »
Also make sure you select the 'mach 3' post processor in CamBam. The generic one works 99% of the time, but the Mach one is fine tuned to play well with Mach's defaults.
Happy machining , Jeff Birt
« Reply #11 on: September 16, 2010, 10:40:06 AM »
I and J are the XY coordinates of the arc center. Absolute mode uses the exact coordinates. Incremental specifies the center relative to the start of the arc.
« Reply #12 on: September 16, 2010, 07:43:45 PM »
Thanks to all who responded. I still have a lot to learn, but I'm getting there. I appreciate all your help.
Best regards to all.
Jeff
