Hello Guest it is November 13, 2026, 01:17:18 PM
Author Topic: switching  (Read 14536 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
switching
« on: September 08, 2010, 05:12:33 AM »
I need to switch 18V 10mA via TTL (turn on/off a plasma torch via the parallel port).
A relay seems a bit overkill for this - doesn't it? and I read somewhere (I think) that such low current is not best switched by a SSR - true? or have I made that up?
Thoughts on cheapest/bestest/nicest/properest way to do this?
Ian
Re: switching
« Reply #1 on: September 08, 2010, 09:16:41 AM »
18V 10mA
cheapest way is transistor.
on-off
Amir
**Even a clock that does not work is right twice a day**
  •  9,377 9,377
Re: switching
« Reply #2 on: September 08, 2010, 12:08:59 PM »
Ian,
The common SSR's need to switch a/c loads as they require the zero crossing point for switching off but having said that I switch my cross hair pointer on / off with a mains connected SSR which powers the wall wart to output the 5Vdc for the pointer. The SSR, which has internal opto isolation, is powered directly from the LPT port.
« Last Edit: September 08, 2010, 12:11:50 PM by Tweakie.CNC »
Offline stirling
  •  2,188 2,188
  • UK
Re: switching
« Reply #3 on: September 10, 2010, 03:07:15 AM »
OK guys - thanks.
Tweakie - have you looked at logic level mosfets for your cross hair pointer - they sound like the mut's nuts for that.
Ian
  •  9,377 9,377
Re: switching
« Reply #4 on: September 10, 2010, 03:26:40 AM »
Thanks Ian but I needed -5volts (relative to the frame) because the body of the pointer is connected to + so it was easier, for me at the time, to get the required negative voltage from a wall wart.
Yes I agree that these logic level switching MOSFET's would be brilliant for a lot of applications. (more circuit board routing is on the cards)  ;D
Re: switching
« Reply #5 on: September 10, 2010, 09:24:12 AM »
logic level mosfets
Using them is not suitable for this issue.
you need only 10ma .you can build a simple circuit by transistor.
Amir
Offline stirling
  •  2,188 2,188
  • UK
Re: switching
« Reply #6 on: September 10, 2010, 11:03:31 AM »
I was suggesting them for Tweakie's laser not my trigger Amir. Keep up  ;D
Re: switching
« Reply #7 on: September 10, 2010, 11:47:59 AM »
sorry. my mistake
