Hello Guest it is November 13, 2026, 03:16:42 PM
Author Topic: Encoder input for Mach 3  (Read 12149 times)
« on: September 06, 2010, 09:09:55 AM »
Hi all,
I hope someone could kindly provide instructions on how to setup an encoder input in Mach 3 Mill.
I have searched the forum, but am still unclear on how to do this.
The encoder I'm using is a 1 ppr Hall effect encoder (http://radionics.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=715-134&x=25&y=14) on the end of my spindle shaft.
It outputs 1 pulse per rev (a/b =50+/- 20%)....Shaft speed is generally 500 - 3000 rpm.
Motor speed is controlled by an external dc drive with a pot setting the speed.
I am unsure of the steps to take for the DRO to indicate the true speed.
Many thanks,
Aidan
« Last Edit: September 06, 2010, 09:16:15 AM by Aidan »
Re: Encoder input for Mach 3
« Reply #1 on: September 06, 2010, 03:23:53 PM »
You want to set this up as the Index on the Inputs page of Ports and pins. Just one input needed.
