Hello Guest it is November 18, 2026, 02:20:14 AM
Author Topic: Cut Profiles Setup  (Read 8020 times)
Cut Profiles Setup
« on: August 26, 2010, 12:48:42 AM »
Hello
I am hoping someone can help me setup or just get in the ballpark with my cut profiles. This profile is for cutting 3/8" steel, I have a Hypertherm Powermax 45 w/ Machine torch & Z floating axis.
I can fill out a few of the options:
Tip Volt Preset 120
THC Delay 1     Is 1 sec too slow or not slow enough?
Tip Saver %       *What is a good starting point?
Arc OK Current    *What is a good starting point?
Cut Current 45
Span Gap 4
Upper Fault Limit   *What is a good starting point?
Lower Fault Limit   *What is a good starting point?
Current Tolerance %  *What is a good starting point?
Any and all info is greatly appreciated.
