Hello Guest it is October 27, 2026, 03:39:36 AM
Author Topic: No post of the G-code  (Read 51897 times)
« on: August 23, 2010, 03:39:25 PM »
Hello,
When i use LazyTurn om my Wondows 7 PC i cannoty get to post the G-code
On my other PC with XP it works fine withe thesame dxf drawing.
The PC calculates the G-code but i cannot post it. Notepad cannot find the document its says as error.
Somebody any idea
Thanks Kees
Re: No post of the G-code
« Reply #1 on: August 23, 2010, 04:16:45 PM »
Kees,
I can't help since i don't use Windows 7.
But will watch for a reply / answer to you  so it can be put in the manual.
« Last Edit: August 23, 2010, 04:18:21 PM by RICH »
« Reply #2 on: August 23, 2010, 04:36:13 PM »
I just tried it here.
When win 7 gave the error message I said OK make a new file.
Then I posted again to the file just created. The post is completely blank.
It does appear to be calculating the path it just won't post.
Mike
« Reply #3 on: September 02, 2010, 10:13:41 AM »
Hi, Look to see if the posted file (G code) is in the Mach folder with the name you assigned to it.
Bill
« Reply #4 on: September 02, 2010, 03:57:50 PM »
Hello Bill,
I tried what you suggested and it works.
Thanks for your help
Kees (Holland)
« Reply #5 on: September 03, 2010, 05:15:37 AM »
Hi Kees,
  Your quite welcome. Back in April of this year, (Art's last dedicated block of time) we discovered this
issue with win7. Look at page 139 of the LT general posts for some other suggestions, on how to make
posts to notepad.
Cheers,
Bill
« Reply #6 on: September 04, 2010, 07:02:33 AM »
Here are some notes from LT page 139. Can someone using W7 fix the text so it provides clear answer to the posting problem.
 ( make note of the version you are using as i think that the home version won't allow you to run in XP mode......could be wrong as  i don't use it )
« Reply #7 on: September 04, 2010, 09:17:51 AM »
Rich
I now put a check in the in the box (windows xp sp2 and now the file is visible and i can save it anywhere i want.
It now works good.
« Reply #8 on: September 06, 2010, 08:43:20 AM »
Hi Rich,
Any version of win7 will allow you to run in compatibility mode. What you can't do is run the xp emulator or whatever it is called. Some programs won't run in compatibility mode and need to run in a winXP environment.
I touched up the file as you asked.
I am attaching it so it will help anybody that needs it.
Mike
« Reply #9 on: September 06, 2010, 08:50:46 AM »
Thanks Mike,
I saved the file such that i will probably never find it later..............at least i know where to look for it here :)
