Hello Guest it is November 13, 2026, 11:38:35 AM
Author Topic: Rotational speed  (Read 32856 times)
Re: Rotational speed
« Reply #10 on: January 26, 2015, 06:41:13 AM »
So there is no "Correction Diameter" box. It's all about setting the steps correctly?
« Reply #11 on: January 26, 2015, 10:11:03 AM »
YES there is a  Rotational axis correction DRO . IT IS used to blend the velocities of XY to the rotary on a combined move.
The Point I am making is you cannot just change the " steps per " to change the velocity. That part MUST be set as per the hardware so that mach3 can move correctly.
(;-)TP
