Hello Guest it is November 17, 2026, 07:42:56 PM
Author Topic: High speed spindle recommendations  (Read 156139 times)
Re: High speed spindle recommendations
« Reply #80 on: August 24, 2010, 10:16:27 AM »
Wasn't this project for a 22,000 RPM spindle?
« Reply #81 on: August 24, 2010, 10:32:50 AM »
20,000 it was  but 1475 would have been fine for a start, especially as that was what the pulleys in stock would give ;D
« Reply #82 on: August 24, 2010, 10:44:19 AM »
Sorry to be dense, but I'm not following this at all. How do you engrave at 1,475 RPM   ???
« Reply #83 on: August 24, 2010, 10:55:09 AM »
easy, you put a zero at the end of that ;D should be 14750
« Reply #84 on: August 24, 2010, 10:59:19 AM »
So where does the 3,000 RPM fit into the puzzle  ???. . .  3,000 at the motor and 14,750 at the spindle? Is that what you have?
« Reply #85 on: August 24, 2010, 01:21:51 PM »
My spindle on the Beaver Mill has 3800rpm top speed the way I have it connected. The gearing in the speeder I made is 3.75 times so that gives me the 14250 (14750 was another typo ;D ). I have been testing out at 3000 rpm spindle speed so output was 11250.
« Reply #86 on: August 24, 2010, 01:46:37 PM »
Hood,
Are those gears you found ground? Otherwise don't think it would be a good idea to spin them at the speeds you like...
Daniel
« Reply #87 on: August 24, 2010, 02:08:11 PM »
They are very nice quality anti backlash gears from an old Bullard lathes encoder/switch housing. They are possibly a bit on the light side but time will tell :) Not sure what speed they would originally have done, will have to put them back in order and see if I think they will do.
« Reply #88 on: August 24, 2010, 04:18:06 PM »
Wow :o  I did not realize you were trying to drive the high speed engraver off the main mill spindle. Almost 4:1 speed increase with a single belt is pretty optimistic.  Going the other way is a whole different animal. If you are now thinking about using gears, you would be well advised to seek out a planetary set. Consider yourself so advised  ;)
In my setup, I am shooting for 40k to 50k rpm, but I'm starting with a pre-balanced 30,000 RPM tool motor.  In any case, good luck and please keep posting your results. This is interesting to follow.
« Last Edit: August 24, 2010, 04:20:43 PM by simpson36 »
« Reply #89 on: August 24, 2010, 04:37:32 PM »
Ok I will take that onboard :) Now what about this idea, this was actually my first but it ended up going by the wayside. I have some small Alpha in line planetary gearboxes that are meant for servo reduction. I was planning on driving it arse for tit and then I discovered the Input (which would be the output) relied on being clamped to the motor shaft. No probs I thought, housing, angular contacts and job done. I then looked up the spec and it says 6000rpm input speed so I decided against it. I am thinking it may be worth a shot, have a couple of angular contacts and would be simple to make up a housing and shaft. If the box screws up its no big deal as I got 2 of them for £12 :)
So what do you think?
Thats quite a bit faster than I need, tool I have is rated to 20,000rpm in stainless I think so anywhere between 15 and 20K would suit me.
Interesting as in funny watching me screw up? ;D
