Hello
Guest
it is
November 19, 2026, 01:14:25 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Ekstrom Carlson Spindle
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Ekstrom Carlson Spindle (Read 13398 times)
Smackre
57
on:
October 20, 2006, 06:53:30 AM »
Well i just ordered a Ekstrom Carlson Spindle to replace my porter cable. I just couldnt deal with the run-out any longer.
Can anyone give me a rundown on the best way to wire the VFD to mach3? The simplist way.
Logged
Chaoticone
5,624
Precision Chaos
Re: Ekstrom Carlson Spindle
Reply #1 on:
October 20, 2006, 07:10:21 AM »
Do you have a breakout board with an analog output?
Logged
If you could see the things I have in my head, you would be laughing too.
Smackre
57
Reply #2 on:
October 20, 2006, 07:28:55 AM »
My breakout board is simple. All it has it the lpt port and blocks to connect wires. I do not think it has a analog output.
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
October 20, 2006, 08:05:57 AM »
Does your VFD have to see a varying input voltage to vary the speed? Any VFD I have fooled with works this way. Do you have any wiring diagrams you can post, or a link? Look at these and see if it helps.
http://www.campbelldesigns.com/mach-spindle-speed-control.php
http://www.cnc4pc.com/Variable_Speed_Control_Board.htm
Last Edit: October 20, 2006, 02:04:23 PM by Chaoticone
Logged
Print
Pages:
1
Go Up
« previous
next »
