Hello Guest it is September 27, 2026, 05:10:08 PM
Author Topic: Pendant plugin  (Read 21631 times)
Pendant plugin
« on: July 30, 2010, 10:23:51 AM »
Hi all
    Does anyone know if the MP03 pendant from Peter Homann works under MSM??
  Larry
Re: Pendant plugin
« Reply #1 on: July 30, 2010, 11:14:15 AM »
While I have no personal experience with that particular pendant, I don't know of a reason it should not work.
In general:
1) Hardware that uses a plugin should work fine. MSM has no knowledge of plugins and doesn't even know they exist.
2) 99.9% of Hardware that uses macros/scripts should be OK also.
What about that other 0.1%?
If a script (of any type, be it hardware related or not) uses resources in the 1700 or 1800 ranges, it will conflict with MSM. See chapter 13 of the user manual.
Author of the MachStdMill Extensions for Mach3
www.CalypsoVentures.com
