Hello
Guest
it is
November 26, 2026, 11:11:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
how to test mach3 with parallel port pin?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: how to test mach3 with parallel port pin? (Read 16309 times)
vominhkhai
3
on:
July 16, 2010, 09:45:44 PM »
hi, Im khai, i have question. How to test mach3 with parallel port pin. i have parallel port with LED. Mach3 run but i don't see led light.
Logged
Carnoustie, Scotland
Re: how to test mach3 with parallel port pin?
Reply #1 on:
July 17, 2010, 02:39:14 AM »
How have you got the LED connected?
When you say it runs do you mean Mach DROs change or do you mean you are you meaning you have motors connected and they run?
Is it an onboard parallel port or is it a PCI one?
Logged
vominhkhai
3
Reply #2 on:
July 17, 2010, 03:13:11 AM »
I'm connect to led with LPT gate ( gate printer).
I don't know signal out put of mach to LPT gate. You can answer the question to me.
thanks
Logged
vominhkhai
3
Reply #3 on:
July 17, 2010, 03:44:12 AM »
i don't know Where the diagnostics page shows outputs on the step and direction pins? I just saw 8 led-on ( at port 1 pin current state, that are ground). mach3 to run when it is just 8 LED scroll on while Dro
Logged
Print
Pages:
1
Go Up
« previous
next »
