Hello Guest it is October 22, 2026, 03:38:15 PM
Author Topic: Plasma , new macro code  (Read 77173 times)
Re: Plasma , new macro code
« Reply #30 on: June 24, 2010, 09:00:47 AM »
I've been working on the same thing this week.  Here is my version.  Runs from a button.
'Code to test gcode travel limits
'John Champlain - June 20, 2010
' Save current XYZ positions
CurrX = GetDRO(0)
CurrY = GetDRO(1)
CurrZ = GetDRO(2)
CurrFeed = GetOemDRO(818)
SafeZ = GetOEMDRO(54)
Dim Msg, Num ' Declare variables.
Title$ = "Check Extents"
Prompt$ = "Enter Feedrate"
Default$ = ""
x% = 75
Y%  =200
Num$ = InputBox(Prompt$, Title$, Default$,X%,Y%) ' Get user input.
' Get gcode travel limits
XMin = GetOEMDRO (4)
XMax = GetOEMDRO(10)
YMin = GetOEMDRO(5)
YMax = GetOEMDRO(11)
' Test travel limits
' Move one axis at a time
Code "F" & num ' set feedrate
Code "G1 Z" & SafeZ 'move Z to safe height
While IsMoving ()
Wend
Code "G1 X" & XMin & "Y" & YMin 'move to minimum XY position
While IsMoving ()
Wend
Code "G1 Y" & YMax 'move to maximum Y position
While IsMoving ()
Wend
Code "G1 X" & XMax 'move to maximum X position
While IsMoving ()
Wend
Code "G1 Y" & YMin 'move to minimum Y position
While IsMoving ()
Wend
Code "G1 X" & XMin 'move to minimum X position
While IsMoving ()
Wend
' Reset to original settings
Code "G1 X" & CurrX & "Y" & CurrY 'reset X
While IsMoving ()
Wend
Code "G1 Z" & CurrZ 'reset Z
While IsMoving ()
Wend
Code "F" & CurrFeed
Code "(Done)"
Regards All,
John Champlain
« Reply #31 on: June 24, 2010, 09:55:21 AM »
Hi John,
Just wanted to let you know your script works correctly for me as well from a button.  :)
« Reply #32 on: June 24, 2010, 10:05:33 AM »
AH, but you left out the regen toolpath(;-) routine to make sure the extents is accurate. Mach does NOT auto correct the extents in the toolpath. Just make sure you do the SET XYAXIS ZERO and REGEN as a manual function before you run it
« Reply #33 on: June 24, 2010, 10:07:43 AM »
That's why I'm guessing it works for me too Terry-
« Reply #34 on: June 24, 2010, 02:24:16 PM »
I see what you mean about the Regen.
John Champlain
« Reply #35 on: June 24, 2010, 10:23:48 PM »
Code revised from suggestions.  I would appreciate someone testing and giving opinion.
John Champlain
CurrX = GetDRO(0)
CurrY = GetDRO(1)
CurrZ = GetDRO(2)
Prompt$ = "Enter Feedrate for Test"
Default$ = ""
x% = 75
Y%  =200
Message "Please Wait While Regenerating"
DoOemButton(160)   'Regen ToolPath
While isLoading()
Wend
Message ""
YMin = GetOEMDRO(5)
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "F" & CurrFeed
DoOEMButton(1002) 'Rewind code
Message "TEST COMPLETE"
Sleep 5000
Message ""
« Reply #36 on: June 25, 2010, 12:39:19 PM »
This one does not work for me as a button, but works with the VB Editor open.
« Reply #37 on: June 25, 2010, 12:50:47 PM »
Thanks Dave,
Any clue as to why it won't work from a button for you?  It works both ways for me (editor and button) using Version R3.042.035.
John Champlain
« Reply #38 on: June 25, 2010, 01:09:01 PM »
Hi John, not a clue as I hardly know anything about VB.
So far all I know is that if it contains the refresh/regen part of the code, it will not work for me.
On the other codes, I just had to edit that out and it works fine from the button.
« Last Edit: June 25, 2010, 01:12:21 PM by budman68 »
« Reply #39 on: June 25, 2010, 08:31:49 PM »
Dave a question for you(;-)  When you run the code from a button do you put the code "IN" the button OR do you make an "Mcode" from the code and call it from the button?
