Hello Guest it is October 22, 2026, 04:11:56 PM
Author Topic: Plasma , new macro code  (Read 77190 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Plasma , new macro code
« Reply #20 on: June 22, 2010, 03:30:24 PM »
well - not being able to leave things alone  ;D I've come up with a version that SEEMS stable at my end. Note the comment at the top of the file - It MUST be run from a button.
Ian
Code: [Select]
'This macro MUST be run from a button
'running it from the MDI for example is not recommended
Begin Dialog Dialog1 60, 60, 104, 70, "Auto Extents"
Text 10, 10, 30, 12, "Feedrate:"
TextBox 44, 10, 50, 12, .feedrate
Text 10, 24, 30, 12, "Dwell:"
TextBox 44, 24, 50, 12, .dwell
Text 10, 38, 30, 12, "Z height:"
TextBox 44, 38, 50, 12, .zHeight
OKButton 10, 54, 40, 12
CancelButton 54,54,40,12
End Dialog
Dim Dlg1 As Dialog1
Dlg1.feedrate=getOEMDRO(818)
Dlg1.dwell=1
Dlg1.zHeight=getOEMDRO(802)
button=Dialog(Dlg1)
If button <> -1 Then
  Exit Sub
End If
DoButton(8)      'ZeroX
DoButton(9)      'ZeroY
While isMoving()
Wend
DoOemButton(160) 'Regen ToolPath
While isLoading()
  sleep 100
Wend
doOEMButton(1002) 'Rewind
While isMoving()
  sleep 100
Wend
xmin = minX()
xmax = maxX()
ymin = minY()
ymax = maxY()
dwell=Dlg1.dwell * 1000
Code "F" & Dlg1.feedRate & " G1 Z" & Dlg1.zHeight
While Ismoving()
  sleep 100
Wend
Code "G1 X" & xmin & " Y" & ymin
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 Y" & ymax
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 X" & xmax
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 Y" & ymin
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 X" & xmin
While Ismoving()
  sleep 100
Wend
MsgBox "Finished",0,"Auto Extents"
« Reply #21 on: June 22, 2010, 04:21:44 PM »
Well thanks for trying Ian, unfortunately same thing for me.
It runs great running it from the VB Editor, but running from the button, it once again cycles through and then the run time just counts up as if the GCode is running.
The new pop up dialog box threw me a bit too, lol!
I appreciate your persistance  ;)
EDIT: I just don't get it, why does it run perfectly through the Editor when open, but not from a button? Is there another way to code a button to do this?
« Reply #22 on: June 22, 2010, 04:40:57 PM »
Ok, may have found something. Ian, I've deleted a bit of your code and got it working.
You'll notice I deleted:
Code: [Select]
DoButton(8)      'ZeroX
DoButton(9)      'ZeroY
While isMoving()
Wend
While isLoading()
  sleep 100
Wend
While isMoving()
  sleep 100
Wend
Now is this going to be safe?
Code: [Select]
End Dialog
Dim Dlg1 As Dialog1
Dlg1.dwell=1
button=Dialog(Dlg1)
  Exit Sub
End If
xmin = minX()
xmax = maxX()
ymin = minY()
ymax = maxY()
While Ismoving()
  sleep 100
Wend
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 Y" & ymax
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 X" & xmax
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 Y" & ymin
While Ismoving()
  sleep 100
Wend
sleep dwell
Code "G1 X" & xmin
While Ismoving()
  sleep 100
Wend
Another question, what can I add to make it go back to the zero coords that I started with when the extents is finished running?
EDIT: The reason I chose to delete those portions was because I was already doing those before running the script. I thought maybe it was getting stuck because it couldn't perform those functions because they were already done! ;D
Thanks again,
« Last Edit: June 22, 2010, 04:45:21 PM by budman68 »
« Reply #23 on: June 22, 2010, 05:31:34 PM »
Ok, so I added this to the code to get it back to X and Y Zero coords:
Code"G1 X0.000 Y0.000"
While Ismoving()
  sleep 100
Wend
Is that correct? I added it like this towards the end:
Code "G1 X" & xmin
While Ismoving()
  sleep 100
Wend
While Ismoving()
  sleep 100
Wend
« Reply #24 on: June 22, 2010, 05:34:50 PM »
Dave if you want to take out the auto part it will run just fine.
NOW last night I worked out a different solution with Sheetcam. I redid the post to output a Dry run around the PART perimeter to verify the material. It also has the block delete charectors in that part so you can turn  the funtion on and off if needed.
AND it has nothing to do with VB(;-) Not as quick and easy BUT it does give a more detailed look at the material fit.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #25 on: June 23, 2010, 02:20:01 AM »
Dave - as Terry says, now you've taken out the toolpath generation it should work fine. That kind of takes away the point of it though really. BUT as it's proving a bit of a mare that's probably the way to go. Interesting you can get it to run from the VB code window but not the button. In my case it's the exact opposite. If I run it from the VB code window all hell breaks loose and it then completely hangs, I have to power cycle the PC to get it back. Your zero code is fine - not sure where it went from mine - it was in there at some point! Sorry the dialog threw you - just me playing about.
Terry - again I see parallels with your approach and what I had to do in my probing routines. Initially I did everything in VB but then as I said had to do most of it in a .DLL - BUT I also had to write the main loop in gcode to get it to work. I think we may just have to accept that Mach's relationship with VB is about as flaky as a box of kellogs ;D
Ian
« Last Edit: June 23, 2010, 02:22:31 AM by stirling »
« Reply #26 on: June 23, 2010, 04:05:57 AM »
Thanks so much fellas, I appreciate the info and for all the help.
This will be nice to have, especially to make sure if any clamps or other obstacles may be in the way.
Have a great day-
« Reply #27 on: June 23, 2010, 06:20:37 PM »
HI IAN, Actually the Sheetcam approach worked very well ran it all day today testing the idea . It is nice to be able to do a dry run
« Reply #28 on: June 23, 2010, 06:30:27 PM »
Ran my sorry little code all day today as well and it worked perfectly for each job I ran.
Thanks so much for inspiring me fellas  8)
« Reply #29 on: June 23, 2010, 07:17:16 PM »
Way to go Big Dave (;-)
