Hello Guest it is November 26, 2026, 01:03:10 AM
Author Topic: Homing weirdness  (Read 27264 times)
Yodawill2000
Re: Homing weirdness
« Reply #10 on: October 15, 2006, 09:39:57 AM »
Thanks again Hood'ster
I ran it up too 1000 and it homes just fine.
Kinda weird as even a super slow Jog worked fine before.
Oh well.
As long as it works !!
 ;D
« Reply #11 on: October 15, 2006, 10:58:52 AM »
Good you are sorted Yoda
Brett, I think your ticking when starting the computer is windows  querying the parallel port. If your breakout has the charge pump feature you should enable it and that should stop any twitching as the drives wont get any pulses at all unless there is a steady stream at a certain frequency.
Yodawill2000
« Reply #12 on: October 15, 2006, 02:14:05 PM »
Not being lucky enough to have a breakout board I just fire the two controllers up after
Windows and Mach are running.
« Reply #13 on: October 16, 2006, 07:24:54 AM »
Yes, I have a charge pump, I think it is flaky though. ??? I got a new seprate pump thursday. I will try that today. It's not real bad, once I open Mach and hit reset, it quits. I will let you know how it does.
What is the dif. between index debounce, and debounce? ???
« Reply #14 on: October 16, 2006, 01:52:27 PM »
 The Index debounce would be, I presume, for the Index Pulse, ie the spindle speed .
« Last Edit: October 16, 2006, 01:57:14 PM by Hood »
