Hello Guest it is November 19, 2026, 07:08:55 PM
Author Topic: Edit g code help  (Read 14136 times)
Edit g code help
« on: June 09, 2010, 08:04:55 AM »
i am trying to edit a g code file   but when i click on edit g code,  the edit box that i have seen on the tutorial video
does not show up.
 G-code edit selection button does not  launch the standard Windows Notepad program .
thanks paul
« Last Edit: June 09, 2010, 08:14:48 AM by woodguy7777 »
  •  9,378 9,378
Re: Edit g code help
« Reply #1 on: June 09, 2010, 08:29:25 AM »
Hi Paul,
Don't know if this helps but under Config / General Config is Notepad specified as the G Code editor ?. (top center of window).
« Reply #2 on: June 09, 2010, 12:41:20 PM »
yes Tweakie it has Notepad specified as the G Code editor .
paul
« Reply #3 on: June 09, 2010, 01:04:47 PM »
I have never had that problem.
What version of Mach are you using?
Are you using the standard screen?
« Reply #4 on: June 09, 2010, 04:35:31 PM »
thanks for the help  is was not a mach3 problem  but a computer problem.
tried another computer and it work
thanks for the time
paul
