Hello Guest it is October 22, 2026, 04:50:36 PM
Author Topic: Polygon Turning  (Read 29588 times)
Re: Polygon Turning
« Reply #10 on: June 14, 2010, 07:23:09 AM »
seriously considering doing this though :) just need to find the time :(
You said it! no going back now ;-) - it would be fantastic to see Mach doing this.
Last page was interesting too - "thread whirling! !!!!! what the heck is that !!!!!!!
ATB
Derek.
 Well I was doing some drawings last night of an idea I have so when I get time I may just do it.
Google thread whirling should get you some info but basically looks like it would really need a sliding head for any length of threads due to rigidity.
It does look good fun doesn't it  ;D
I wonder if there is an optimal cutter diameter for say a max of 3/4" AF hex?  In our case the smaller the cutter dia the better and I see they do one 40mm dia!  Accoring to the pdf example you want the cutter to be (very) approx 3.5 times the af BUT could a 'hobby' type machine cope with the high speed intermittant cut?
There is only one way to find out - HOOD GET ONTO IT!  (I know you want to)
 Rob  ;)
The bigger the dia of the cutter the flatter the flat will be. As for me doing it so you can see how a hobby size machine would cope I am afraid its quite a big lathe I have, probably fit some of the hobby lathes in my toolpost ;D
Heres my lathe, to get an idea of its size that is a 10inch 3 jaw chuck and a 32mm dia boring bar in the front toolpost.
« Last Edit: June 14, 2010, 07:33:18 AM by Hood »
Re: Polygon Turning
« Reply #11 on: June 14, 2010, 08:41:50 AM »
Oh well with a machine like, there's nothing stopping you!  It wouldn't be too difficult to rig up a servo to a spindle that is held in that whopper of a toolpost just to see if it works.......... but i think it will only work properly if many photographs are taken through the process  ;)
Im really trying to work out how I can place a polygon turning attatchment to my machine as it would be such an awesome feature.
Keep having polygon thoughts!
Rob.
