Hello Guest it is November 11, 2026, 04:05:41 AM
Author Topic: New PC Loosing Steps (I think)  (Read 61158 times)
Re: New PC Loosing Steps (I think)
« Reply #10 on: May 31, 2010, 06:22:26 AM »
what you dont use another model ?
for example:
http://linitx.com/viewproduct.php?prodid=12601
MINI +1.66 CPU+ parallel+low price
**Even a clock that does not work is right twice a day**
« Reply #11 on: May 31, 2010, 06:50:05 AM »
for example:
Two reasons
1. I need an external device to get the frequency I require for my axis so I use the SmoothStepper.
2. see pic ;)
« Reply #12 on: May 31, 2010, 12:04:59 PM »
Well I have tried everything I can think of and nothing has worked, going for the complete reinstall of windows XP then a fresh install of MACH fingers crossed : (
« Reply #13 on: May 31, 2010, 12:20:38 PM »
you must change your PC.
No need for change operating system .
« Reply #14 on: May 31, 2010, 12:41:11 PM »
I have now tried two PC's both with the problem I am thinking more about the smooth stepper!
« Reply #16 on: May 31, 2010, 01:35:23 PM »
thx.
very good
« Reply #17 on: May 31, 2010, 03:20:05 PM »
Hi Ger
I have looked through my bios but I do not seem to have the options your other thread talks about.
I have done a complete new install of XP carried out all the optimisations apart from standard PC as this will not allow the boot from my sata hard drive just about to install Mach and try again.
Will keep you all posted with my progress or not which ever the case maybe
Andy
« Reply #18 on: May 31, 2010, 05:23:58 PM »
On my old Dell, Mach3 will NOT run smoothly unless set to Standard PC. That very well could be the problem.
« Reply #19 on: May 31, 2010, 05:35:21 PM »
Hi Gerry
Thanks for the help, do you know how to get a pc to run as a standard pc and boot from a sata hard drive?
Andy
