Hello Guest it is October 30, 2026, 07:00:53 PM
Author Topic: Pins 2 to 9 as inputs  (Read 10259 times)
Offline Sweep
  •  150 150
    • pollz.co.uk
« on: May 27, 2010, 12:43:19 PM »
As standard, I believe, the pins on the parallel port which are inputs are 10, 11, 12, 13, & 15.
If on my 2nd parallel I define "pins 2-9 as inputs" does this change pins 10, 11, 12, 13, & 15 to outputs as the manual says that I should have 13 inputs, yet I count a total of 18 ?
...Sweep
Re: Pins 2 to 9 as inputs
« Reply #1 on: May 27, 2010, 02:01:43 PM »
You are correct, the manual is wrong :)
Few other bits and bobs in the manual that are not quite right but nothing major.
Offline Sweep
  •  150 150
    • pollz.co.uk
« Reply #2 on: May 27, 2010, 02:30:20 PM »
Me correct? Well after my last thread on 'lost steps' that makes a pleasant change  ;)
At least it is good news this time; 18 inputs yippee !
...Sweep
« Reply #3 on: May 27, 2010, 02:39:28 PM »
Lets just hope you dont end up needing only 17 Inputs and want 17 Outputs ;D
