Hello Guest it is November 19, 2026, 07:42:56 PM
Author Topic: Using a Variable  (Read 33303 times)
Re: Using a Variable
« Reply #10 on: May 26, 2010, 12:27:38 PM »
Br549-
 I am starting to understanding of what I am trying to do.
I have a few questions:
1.  What is a Scam post?
2  What is a Macropump?
Is there are range of variables that I should use, or a range of variables I need to stay away from?
that is a good idea about pierce count.
thanks for all the help
Steve
about Scam post : in folder post in sheetcam ,there are many file that constructive Gcode with our custom settings.
about macropump: When we want something check constantly we can use this function.
**Even a clock that does not work is right twice a day**
« Reply #11 on: May 26, 2010, 03:12:07 PM »
The Scam(SheetCam) post is the part of Scam that actually writes the Gcode based on the drawing and other parameters. Less will handle the modifications of that part for you.
A Macropump is a piece of code that mach runs continuesly. I t can be used for uses such as this.
You can use any Gcode Var # and you will only use 1 AND you have to let LES know which one you choose.  I would use one in the range of 500-600 as those Vars are stored in MachsXML file when it shuts down and will always be there at startup. The other #Vars are not retained when Mach shuts down.
Also you can set the dro to be stored as well so you have double safe values on startup(;-)
Hope that helps, if not we will try again(;-)
« Reply #12 on: May 26, 2010, 11:08:04 PM »
BR549-
Thanks for the information.  It does not look like it should be that hard to accomplish what I am trying to do.  Now to find some extra time.  I don't think I am going to make it to the shop until this weekend.  Work has picked up, I guess that is a good thing.
Steve
« Reply #13 on: May 27, 2010, 03:41:12 PM »
i think this Thread is forgotten.
please describe a practical example.
Amir
« Reply #14 on: June 28, 2010, 11:37:51 AM »
OK-
I finally have time to work on this project again!!
Everything is kinda working, and I am trying to track down where the problem is.
The sheetcam POST has been modified so that it uses variable #500 to determine preheat time for the Oxy fuel torch.
The problem is that the only way I can change the variable is to edit the g-code.
There is a line towards the top that sets the variable to what the tool setpoint is in sheetcam.
the line is
N********* P#500=20
so if i edit this line then I can change the preheat time through the g-code.
I tried to change the #500 variable using the MDI and it did not change anything.
I entered this in the MDI      VAR #500=10
the problem is that I am not sure if the variable changed.
So here is what I think I need for now
a small window that has the actual value of variable 500
and a up and a down arrow, that when clicked on will either add or subtract 1 sec to the variable #500
then display the new value of the Variable #500 in the window.
How would I go about this????
thanks for the help
Steve
« Reply #15 on: June 28, 2010, 06:32:36 PM »
from the MDI line type            #500=20       then press enter
To make it seemless you need to install a OEMDRO on the screen, then add an update button beside it.
Add code to the button to update the var based on the OemDro
SetVar(500,Getoemdro(*********))      where ********* is the OEMDRO# you used. This way whenever you want to update the preheat number just input the new value then press update.
« Reply #16 on: June 28, 2010, 07:12:58 PM »
OOPS message timed out,eating supper(;-)
Add an OemDro to the screen. Then add a Raise and Lower button to the side.
To the Macropump add the following code, This will update the OemDro with the Var500 value UNLESS it is a negative number then it sets Zero
If GetOemDro(***) < 0 Then SetOemDro(500,0)       ' Where *** is the OemDro Number
Else
SetOemdro(***,GetVar(500))
End If
Next add some button code to the up and down buttons
Up
SetVar(500,(GetVar(500)+1))
Down
SetVar(500,(Getvar(500) -1))
That should about do it, If you need more help just holler
« Reply #17 on: June 28, 2010, 11:08:38 PM »
BR549-
I will try that first thing in the morning.  It is too late to go to the shop tonight
Steve
« Reply #18 on: June 29, 2010, 07:59:36 PM »
Steve did you get your Scam post sorted out? I saw where you did not have the OnToolChange() included in the post so the Var value was never included in the output.
« Reply #19 on: June 29, 2010, 10:59:13 PM »
BR549-
My wife made me mow the fields.  :(  but there is always tomorrow :)
I should make it to the shop in the morning.  I should have 4-5 hours before I goto work, so I will let you know how it turns out.
Thanks again
Steve
