Hello Guest it is November 22, 2026, 08:49:46 AM
Author Topic: mach3 and beam saw  (Read 19571 times)
Re: mach3 and beam saw
« Reply #10 on: May 28, 2010, 09:27:42 PM »
I think you mean it cuts the clamps on small parts? So after the beam comes down, you want to open the clamps, and back them up before the cut?
How are you creating the g-code? I think what you want to do may be better handled in the g-code, or whatever creates it.
« Reply #11 on: May 29, 2010, 05:00:09 PM »
Hi Ger21
G code create other program!
I have to watch it let him not cut the clamps, which moves the board, off.
Csaba
« Reply #12 on: June 22, 2010, 02:34:19 AM »
Hi
I did code, if one input is active then run macro.
There's also a task in your gcode,  y and u  to replace the x letters marked.
World Cup so you can VB sript?
