Hello Guest it is November 01, 2026, 12:48:45 AM
Author Topic: Bessie Rover 13 router retrofit with Yaskawa servo packs? Need help.  (Read 16327 times)
Offline DaOne
  •  236 236
I have a Bessie Rover 13 that has a old point to point control (NC400 Pro). I would like to convert it to Mach 3 so it will run standard G-code and do 3D carving. Right now its fitted with yaskawa cacr-sr02be12g-e servo packs. Anyone have any experience with driving them via Mach 3?
Here is the manuel for the drives...
http://www.yaskawa.com/site/dmservo.nsf/aa8198da5462fcbe86256c59004e4bcb/86256ec30069fdef86256de2005b9656/$FILE/TSE-S800-11.1E.pdf
i have two YASKAWA CACR-SR15BC  . and them are analog.
you should conver step/dir to -+10V .
Inexpensive way :use YAPSC10V (http://www.cnczone.com/forums/showthread.php?t=74532)
amir
**Even a clock that does not work is right twice a day**
You can also run them with a DSPMC or Galil.
http://www.vitalsystem.com/web/motion/dspmc.php
Converting a point to point machine to Mach3 control in not for the faint of heart. There is another thread here of someone converting a Busellato. Might want to search for it.
Offline DaOne
  •  236 236
The encoders on the servo motors are UTOPH-81AVF. I cant seem to locate much info on them. Anyone know what they are and if they are compatible with one of the converters mentioned?
Offline kf2qd
  •  157 157
Manual won't come up for me - Can the drives be configurted for Step & Direction?
The newer Yaskawa Sigma series can be setup for Analog or Step&Direction. Omron sells a repackaged version of the Yaskawa drive that they call SmartStep that are stepper input only. I have also used Mitsubuishi drives that were step & Direction, but I preferred the Omron/Yaskawa drives. If you have the money one of these options might be easier to work with and you can get a local vendor to give you some assistance, depending on your level of electronics experience. It might cost a little more but you do buy access to their experience which might be what makes or breaks your project or your time frame for operation..
There are others out there - Automation Direct and others but I have zero experience with them.
Offline DaOne
  •  236 236
I think the drives are speed control only. I would like to use the drives that are in there because they are already mounted and work great. Plenty of power. I think one of the analog to step/direction solutions is the way to go if the encoders will work with them.
