Hello Guest it is October 20, 2026, 03:53:19 PM
Author Topic: External Button for Auto Tool Zero  (Read 57690 times)
Offline Greolt
  •  956 956
Re: External Button for Auto Tool Zero
« Reply #20 on: May 29, 2010, 07:30:44 PM »
I realized that the process works well, But only during the run of the code does not work
why?
Perhaps you need to provide some more information so that others can help.
What is the VB macro that is failing?  Does it run from the editor?   Can you call it from the MDI?  What happens when you step through it with the editor?
Greg
« Reply #21 on: May 30, 2010, 12:52:09 AM »
i attach my file.
this macro should work during cut.
when trigger input#1 ,first feedhold>Torch off>stop>set position>...
i test it,macro is ok.
yes
when is stationary, input#1 work and trigger macro but in during cut dont work
please check them.
**Even a clock that does not work is right twice a day**
« Reply #22 on: May 31, 2010, 09:52:48 AM »
Someone faced with this problem
Offline Greolt
  •  956 956
« Reply #23 on: May 31, 2010, 03:34:20 PM »
I have no experience with plasma.
Can you trigger the macro with an onscreen button during a cut?
Is there noise swamping the input while plasma is running?
Greg
« Reply #24 on: June 01, 2010, 12:46:54 AM »
This problem is not in plasma. General case.
yes, i can with button and no problem even during cut
no, i dont test this Steps with machine. i test only with PC but when i run code ,Trigger does not cause to activate macro
If possible please test my file on the your PC.
may I get wrong step.
again thx.
Amir
« Reply #25 on: June 03, 2010, 02:34:32 AM »
In your Macropump.m1s
you need to change GetOEMled(1140) to GetUserLED(1140), there is NO OEM Leds in that range.
Also in your Brain:
   You will need to INVERT your noop, for your UserLED to be ON when your Input1 is ON, you will have to use a INverted op. otherwise when the Brian says your Screen User LED is on, it will be off, and vice versa.
so you brain rung should be:
INPUT1 -> Invert signal -> UserLED
(I recommend reading the "Brains Users Guide" in the member docs section.)
BTW: make sure under Ports and Pins for the INPUT1 signal you have it enabled, AND make sure the Logic (active high, or active low), is correct for what you want the state of that signal doing when active.
scott
« Reply #26 on: June 03, 2010, 02:37:19 AM »
thx Scott
i check it
Amir
« Reply #27 on: June 03, 2010, 02:48:59 AM »
i change OEMled to userled and invert signal.
result :
no change. actually it work well but only when code dont run( Axes are no moving )
« Reply #28 on: June 06, 2010, 03:48:21 PM »
I renamed my zerotool macro to M615 and now everything works fine. Thanks for everybody's help.
Offline johnv
  •  43 43
« Reply #29 on: September 18, 2010, 04:03:12 PM »
Hi All,
I would appreciate if ranchak or greg would enclose a corrected m1s & brn file. I'm been trying all different versions and am at a standstill. Thanks in advance.
Johnv
