Hello Guest it is October 24, 2026, 06:59:09 AM
Author Topic: Confused about Steps, Pulses calculations  (Read 21983 times)
Offline Vogavt
  •  260 260
Re: Confused about Steps, Pulses calculations
« Reply #10 on: April 27, 2010, 05:58:39 PM »
Ignore the last post. I couldn't get the pics to show up and the time limit for modification expired. What's up with that?
Anyway, here's another attempt. The pics show the caliper holder base that obviously mounts to the bed and the slider mount for the caliper that mounts in the spindle.  I made this this past weekend and I think it's woriking like I designed it.  I have no clue as to what a "Speciialized Tool" is supposed to look like. The base is simply squared off with an engineering square (Groz) and bolted to the bed. Therefore, the slots were milled perpendicular to the bottom surface to ensure when I move the axis, it moves parallel to the bed.  The sliding holder portion is also slotted and mounts in the spindle.
It's made out of 3/4" 6061 T6 Aluminum.
Criticism is okay, I've got broad sholders, so tell me what you think, please.
Vogavt
P.S. Maybe some moderator can clean up the previous post. I DELETED IT  RICH
« Last Edit: April 27, 2010, 07:56:32 PM by RICH »
« Reply #11 on: April 27, 2010, 07:54:10 PM »
Have you swapped the cables yet as suggested?
Offline Vogavt
  •  260 260
« Reply #12 on: April 28, 2010, 07:27:35 AM »
No, not yet, but will this afternoon.  Good suggestion.
Vogavt
« Last Edit: April 28, 2010, 07:29:43 AM by Vogavt »
