Hello Guest it is October 29, 2026, 09:25:25 AM
Author Topic: Lost step, but only on Program Run page - Smooth on Diagnostics Page  (Read 15749 times)
jrlifter
Mach 3 looses steps like crazy when on the Program Run page and the axis are jogged.  When I go to the Diagnotic page and move around they are smooth and never miss a beat.  This is on a Taig mini-mill, by the way.   Any ideas?
Jeff
Re: Lost step, but only on Program Run page - Smooth on Diagnostics Page
« Reply #1 on: October 09, 2006, 07:16:26 AM »
Are they jogging, or moving at the same rate in run,jog, and diag.?
jrlifter
« Reply #2 on: October 09, 2006, 10:45:48 AM »
Whatever I set the jog rate to is what they travel.  If I set it for step then they step by the set inc. also.  If I set it for a .2 step the axis may loose 2 or 3 steps in that distance, but if I do the same on the Diagnostic page it steps perfect every time.
« Reply #3 on: October 09, 2006, 03:36:17 PM »
What version of Mach are you running?
« Reply #4 on: October 09, 2006, 09:03:25 PM »
What do you have for a computer?
www.newfangledsolutions.com
www.machsupport.com
jrlifter
« Reply #5 on: October 10, 2006, 11:26:04 AM »
I am using Mach3.  I primarily use a 2ghz Inspiron laptop with 1gig ram.  I have 4 other destops in the room and have tried them as well with the same results.  The diagnostic utility does show my signal is pretty dirty, but I don't understand why it would clean up and work great just by switching the page within Mach3?   :-\
« Reply #6 on: October 12, 2006, 06:20:02 AM »
well there was an error in the LED class that could be giving you this trouble. Try the newest version and that could help.
Brian
www.machsupport.com
