Hello
Guest
it is
October 29, 2026, 09:24:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Lost step, but only on Program Run page - Smooth on Diagnostics Page
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Lost step, but only on Program Run page - Smooth on Diagnostics Page (Read 15747 times)
jrlifter
on:
October 09, 2006, 12:08:20 AM »
Mach 3 looses steps like crazy when on the Program Run page and the axis are jogged. When I go to the Diagnotic page and move around they are smooth and never miss a beat. This is on a Taig mini-mill, by the way. Any ideas?
Jeff
Chaoticone
5,624
Precision Chaos
Re: Lost step, but only on Program Run page - Smooth on Diagnostics Page
Reply #1 on:
October 09, 2006, 07:16:26 AM »
Are they jogging, or moving at the same rate in run,jog, and diag.?
If you could see the things I have in my head, you would be laughing too.
jrlifter
Reply #2 on:
October 09, 2006, 10:45:48 AM »
Whatever I set the jog rate to is what they travel. If I set it for step then they step by the set inc. also. If I set it for a .2 step the axis may loose 2 or 3 steps in that distance, but if I do the same on the Diagnostic page it steps perfect every time.
Chaoticone
5,624
Precision Chaos
Reply #3 on:
October 09, 2006, 03:36:17 PM »
What version of Mach are you running?
Brian Barker
3,860
Reply #4 on:
October 09, 2006, 09:03:25 PM »
What do you have for a computer?
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
jrlifter
Reply #5 on:
October 10, 2006, 11:26:04 AM »
I am using Mach3. I primarily use a 2ghz Inspiron laptop with 1gig ram. I have 4 other destops in the room and have tried them as well with the same results. The diagnostic utility does show my signal is pretty dirty, but I don't understand why it would clean up and work great just by switching the page within Mach3?
Brian Barker
3,860
Reply #6 on:
October 12, 2006, 06:20:02 AM »
well there was an error in the LED class that could be giving you this trouble. Try the newest version and that could help.
Brian
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
