Hello Guest it is October 21, 2026, 08:00:39 AM
Author Topic: Jogging with Brains  (Read 8532 times)
Offline Dom
  •  22 22
    • Bridgeport CNC Retrofit Blog
Jogging with Brains
« on: April 21, 2010, 07:40:00 AM »
Immagine a simple pendant for one axis with three buttons.  X+, X- and speed boost. The idea being that pressing either direction button on its own would jog the axis at a very slow speed but holding down the speed increase button at the same time would make the axis jog much faster in the chosen direction.
Is this a sensible thing to try and do in a brain ? and would anyone be able to help me achieve this ?
Offline Dom
  •  22 22
Re: Jogging with Brains
« Reply #1 on: April 21, 2010, 06:20:38 PM »
Anyone .... ?
I've attached a copy of my brain attempt. So far I am able to hold down one button and get an output and then if I press a second button at the same time it will stop the first output and start a second one. However pressing the buttons individually trigger the same output, where as I need them to trigger different outputs. Does this make sense?
Should I even be attempting this in a brain or is such complexity better suited to the slower VBA macropump implementation?
« Reply #2 on: July 29, 2010, 10:55:34 AM »
This may be of help to you I also have only 1 MPG I added 4 buttons for X,Y,Z,A and the attached brains use the buttons to select the axis that the MPG will move. they also watch the limit switches. because I have Separate + and - limit switches these brains can detect which limit switch has been hit and will move the axis off the limit switch when the button for that axis is pressed.
I use these brains with the auto limit switch override feature in mach this way if I hit a limit switch I need to press the reset button then the axis that hit the limit.
 I did this because I I knew that sooner or later I would turn the MPG the wrong way while on the limit switch and break something now it just does the right thing :)
anyway it is not exactly what you are looking for and I was hoping to add a similar option for changing the MPG rate but never got to it.
Herb
