Hello
Guest
it is
October 31, 2026, 07:29:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
RhinoCAM post processor
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: RhinoCAM post processor (Read 17277 times)
kdoney
78
on:
October 08, 2006, 07:00:25 AM »
The RhinoCAM post processor always gives me a G43 in the setup code but the control doesn't understand it (Mach3 1.84.001). Is the post wrong?
Re: RhinoCAM post processor
Reply #1 on:
October 08, 2006, 08:47:52 AM »
Can you post a sample code, then it could be tested by others. G43 works fine for me.
kdoney
78
Reply #2 on:
October 08, 2006, 09:23:23 AM »
It is a Mach2 post processor but I thought it still should work.
Reply #3 on:
October 08, 2006, 09:42:02 AM »
I am a total beginner at G code but I think there should be an H before the offset value, eg line should read G43 H0
Take this with a pinch of salt as I said I am a novice when it comes to code.
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #4 on:
October 08, 2006, 04:28:32 PM »
Hood is correct in his reply, the G43 should be followed by a H value, do you always get a zero, try telling rhino you are using tool 1 or above and see if that changes the output.
Graham.
captain_chaos
4
Reply #5 on:
October 14, 2006, 05:56:59 AM »
Hi kdoney,
when i changed from Mach2 to Mach3 i had the same error.
If you edit the g-code with Mach it will work fine again. Only delete the 0 behind G43, that`s all.
I think you can change the Postprocessor settings inside Rhinocam so it will never write the 0 again.
Andy
Print
Pages:
1
Go Up
« previous
next »
