Hello Guest it is October 20, 2026, 02:33:34 PM
Author Topic: Spindle speed hunts  (Read 8888 times)
Spindle speed hunts
« on: April 10, 2010, 09:18:50 AM »
Set speed to 4000 rpm but machine goes up to 5000 rpm and then backs off to 4000 rpm and is ok then till you change speed again and the same happens
  •  9,374 9,374
Re: Spindle speed hunts
« Reply #1 on: April 10, 2010, 11:32:09 AM »
If you are using VFD driven form a 0-10 Volt signal (or similar) then it might be worth checking this voltage whilst you change speed to see how quickly the voltage stabilizes.
