Hello Guest it is October 30, 2026, 07:56:58 AM
Author Topic: Help, how to solve/find out X axis from "lost steps" ?  (Read 12936 times)
« on: April 05, 2010, 12:24:52 AM »
when I do round pocket cutting, is not round anymore.
I think X axis is the problem.
if I test x 0 and x 50 and x 0 (repet) I found out it shift.
my question, how to narrow the probelm, is it the motor ? or the controller ?
how so find out the easiest way ?
should I test anything ?
thankyou for your help
Cal
Re: Help, how to solve/find out X axis from "lost steps" ?
« Reply #1 on: April 05, 2010, 12:59:01 AM »
Drop the Velocity and Acceleration for the X in motor tuning to half of what you have and see if it then works, if it does then try increasing until you have issues again.
« Reply #2 on: April 05, 2010, 08:42:08 AM »
Hood,
Thank you for your suggestion, so far i works, but I will try to the bigger project.
Cal
« Reply #3 on: April 09, 2010, 09:01:41 AM »
Hood,
I have a probl;em, same problem, after I decrease the velocisty and accl. last time wiorks fine, but now it happening again.
but only at X axis.
I suspect the motor or the controller, do you have any idea ?
the Y axis seems pretty ok.
how to test that the motor is not getting weak ??
and how to tested ?
Help please....
regards
cal
« Reply #4 on: April 09, 2010, 10:16:12 AM »
calico, when I jog an access to a point and back and there is a shift, I usually consider that to be backlash.
Do you have reason to believe there is no backlash?  If you're running ballscrews with double nuts, perhaps one came loose and backed off the preload.
If you're sure this is not backlash, it could be lost steps due to motor tuning, or it could also be noise.
Those are my thoughts on it.
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Offline kf2qd
  •  157 157
« Reply #5 on: April 12, 2010, 02:56:22 PM »
Check out the coupling (however you get the power from the motor to the screws/gears) and check to make sure that everything is properly tight. If you have anything loose and slipping no tuning or other adjustmants will eleminate the problem. Check all mechanical connections int you drive and then go to motor tuning.
