Hello Guest it is November 13, 2026, 01:29:48 PM
Author Topic: Setting up axis home (Newbie)  (Read 21103 times)
Re: Setting up axis home (Newbie)
« Reply #10 on: April 04, 2010, 07:54:50 AM »
I'm a newb also so bear with me. When you "ref home" on z doe it ref home properly and zero out? Did you set your "switch offset" in your Sheetcam post to the proper height?
Just my 2 cents worth.
Mike
« Reply #11 on: April 04, 2010, 08:04:06 AM »
Depends on whom you ask..
Yes our Mach3 does home properly when we press the "Ref All Home" button, and it will set the machine coords to "0" properly. We did the required correct setups in Mach3's config->Ports And Pins and config->Homing/Limits. And our mill delivers referencing signals (actually limit switch signals). I can go with you thru the details. I can't help you with Sheetcam.
