Hello Guest it is October 26, 2026, 03:43:56 PM
Author Topic: How do you set the home position and do a simple 2d profile  (Read 41016 times)
Hi to all,
Just curious how we go about setting the home position with Lasyturn
and also how do we machine a simple profile without the tool going to
x0 and cutting of the stock at the end.
I have enclosed a picture of what I mean.
Tried so many things which didnt work.
So far excellent addon, simple and easy !  ;D
Any thoughts,
Regards
Whatda?
Re: How do you set the home position and do a simple 2d profile
« Reply #1 on: April 03, 2010, 07:21:46 AM »
WHATDA,
Attached is a rough draft of Appendix "F"  of the LazyTurn Manual which should answer most questions and then some.
You can't print the document but you can read it.
« Reply #2 on: April 11, 2010, 11:36:10 AM »
Hay Whatda
Could you attach the dxf and the *.tap file
Greetings:
Willem
