Hello
Guest
it is
November 13, 2026, 10:02:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
LED question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: LED question (Read 9235 times)
CharliePatten
46
LED question
on:
April 02, 2010, 05:10:12 AM »
How do you get the X zero, Y zero, and Z zero LEDs to change from green to red after you hit an E-Stop? (this would indicate that you should do a "home ref." before continuing) My system used to do this and now for some reason it is not!
Logged
Overloaded
4,923
Re: LED question
Reply #1 on:
April 02, 2010, 06:48:13 AM »
I dont' recall an estop de-referencing the axis's.
Bumping a limit switch will though.
Or....putting this in the macro pump works as well.
If GetOEMLED (800) Then
DoOEMButton 240
End If
Russ
Last Edit: April 02, 2010, 07:08:41 AM by Overloaded
Logged
Print
Pages:
1
Go Up
« previous
next »
