Hello Guest it is November 22, 2026, 10:05:25 AM
Author Topic: Threading no go?  (Read 25685 times)
Re: Threading no go?
« Reply #10 on: March 30, 2010, 12:20:01 PM »
Is your CPU speed greater than 2.1 GHz. If so you will get a negative spindle speed if you are running mach on version R3.042.032. Updating to the current release should solve the problem.
Peter
« Reply #11 on: April 01, 2010, 02:42:38 AM »
PC is a 3GHz Core Duo
I don't even have an option to turn on the threading plugin.
I will try updating now
« Reply #12 on: April 01, 2010, 03:12:40 AM »
Yes updating fixed the spindle speed problem Thanks. However it still will not thread in sync mode. Trying to upload my xml but my internets not co-operating today
« Reply #13 on: April 01, 2010, 03:27:16 AM »
Not sure if you have said or not but is it a licensed copy you are using? If its the Demo threading is not activated. If you do have a licence make sure it is actually seen by Mach by going to Help menu then About Mach3......  if you see your licensed name then that's not the problem, if it says demo then make sure your licence is in the correct folder.
« Reply #14 on: April 01, 2010, 04:58:03 AM »
Posted just for information:
Feb 14/2010
Release 3.042.037
-- Driver update for threading
« Reply #15 on: April 12, 2010, 02:59:39 AM »
Sorry for the long reply been on holiday. Yes it is an unlicensed copy so I guess that solves it. Thanks
