Hello Guest it is November 18, 2026, 01:47:54 PM
Author Topic: limit switch problem  (Read 38925 times)
Re: limit switch problem
« Reply #20 on: March 26, 2010, 04:05:50 PM »
Then I would say hardware is more likely to be at fault. Change the active state of your E-Stop and remove your port cable and test with a voltmeter directly on the parallel port pins.
« Reply #21 on: March 27, 2010, 08:12:12 AM »
Thanks Hood. I have located a faulty 25 cond. ribbon cable inside my control enclosure as the cause of the latest problem. Now that I have fixed that, I can get back to solving the previous problem.
Charlie
« Reply #22 on: March 27, 2010, 11:25:37 AM »
Thats good to hear Charlie. I still think your limit problem is hardware related as well as I think you said you get the Home LED occasionally flashing. If you can try like I suggested and connect a wire directly to your bob in place of the limit switches and see if the problem is still there even when you enable limits.
« Reply #23 on: April 01, 2010, 07:31:20 AM »
Hood:
I have finally located the source of the "noise" that was triggering my "reset" button, however the answer needs an explanation! I have all my limit switch (shielded) cables grounded on the limit switch end only. When I remove the ground wire, everything works normally with no triggering of the "reset" button. This is just the opposite of what you would expect. I have tested this both ways over an 8 hour period and feel confident that this was the problem. Any thoughts?
Charlie
« Reply #24 on: April 01, 2010, 11:05:28 AM »
Sounds like your ground point may not be a ground?
« Reply #25 on: April 01, 2010, 11:37:46 AM »
Logical conclusion! I will look into that. Thanks.
